BitmapDrawer Component
EtsDriver
Has thanked: 345 times
Been thanked: 227 times
Post by EtsDriver »
Hi!
Has anyone tried playing around with this?
I had a try, but i could not get a one black 10pix x 10pix sized cube as 8 bit bmp to show up... Hope the help system will cover this component on some levels and show us how to deal with memory usage using this component. Does the code need some kind of specific display, or will it work with any display included in flowcode v7?
This thing seems great for simplifying some of the old HMI codes that will need some customer specific logos and appearance to be put into the software. :)
Idea for continuing development:
Make some kind of simulation dashboard only component that shows like how much ROM memory for example these BitmapDrawer's might eat from your target micro...
Has thanked: 481 times
Been thanked: 699 times
Re: BitmapDrawer Component
It only currently supports 1-bit and 24-bit BMP files
Yes I have an example for this component in the wings. I'll try and get it added to the wiki next week. I'm not in the office today so don't have it to hand.
The component will work with any of the graphical displays in Flowcode v7 and also the new MIAC range with gLCDs. Just set the property in the bitmap drawer component to point to the display you want to draw to.
The file length property shows how many bytes the image you are using will consume of your ROM memory. You can find how much ROM memory is available on your device using the Device Helper component.
Currently only 1-bit monochrome or 24-bit bitmap images are supported but I do have a plan for getting 8-bit files up and running so hopefully these will be included soon.
Example as promised.
BitmapDrawerDemo.zip
(4.15 KiB) Downloaded 413 times
Another example here with animated eyes - Example2.
http://www.flowcode.co.uk/wikiv7/index.p ... b2297168a5
This runs well in simulation. On the EBM001 with a 16F1937 you can see the redraw. This is because 1) the 16F1937 is not at full speed (19.6MHz instead of 32MHz) and even then not all that powerful and 2) the EBM001 is 16-bits per pixel so lots of data to transfer.
On a monochrome display (1-bit per pixel) this should fly.
The ECIO40P16 is a good target for colour images to allow for large ROM spaces for your files and a very fast processor combined with easy programming. An arduino should also do a reasonable job with colour images.
16F1937 running at 32MHz = 8 million 8-bit ops per second
Arduino running at 16MHz = 16 million 8-bit ops per second
ECIO40P16 or EB091 = 70 million 16-bit ops per second
AbhijitR
Has thanked: 284 times
Been thanked: 80 times
Post by AbhijitR »
Hello! Ben
This is to thank you and Matrix team for making the programming task so easy (piece of cake) by introducing such innovative utilities/tools.
Thank again, cheers...
Abhi
