Help with how to make definitions in FC
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi All,
Please help me understand the most easy way to do the following in FC,
In C I can do this
#define  INITSTATE    1
#define  RUNSTATE    2
#define  ERRORSATE  3
then in some were in the code I can load this definition to a Varaible which is used to select the case of my case structure(Statemachine)
MachineState = RUN
Then in the case structure
Switch (MachineState )
  and so on
How can I do this definitions in FC? :D
much appreciated
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: help with how to make definitions in FC
Post by kersing »
In the project explorer create constants in the globals section.
(2.67 KiB) Downloaded 1819 times
Now you can select them in the switch:
(10.29 KiB) Downloaded 1819 times
― C.S. Lewis
QMESAR
Post by QMESAR »
Thank you very much Kersing this really helps me a whole lot :D
Really appreciate your help
