Dear adviser
when I am trying to make a new project or to open the last projects I don`t have the topic menu (FILE VIEW HELP)
there for I can not set the components to program
what can be done to fix this problem
Losing Menu Bar
Nasim Khaliqhey
- Has thanked: 1 time
- Been thanked: 3 times
Re: losing manu
Many thanks for letting us know.
I believe this is a bug in the Flowcode executable that has now been fixed and so will be fixed in the next update patch we release.
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: losing manu
As a workaround, unzip and run the attached registry file to reset the Flowcode workspace and recover the menu. You will need to do this when Flowcode is not open.
The problem seems to occur when the menu bar is undocked from its default position.
Steve,
Steve,
- reset_flowcode_workspace.7z
- (265 Bytes) Downloaded 364 times
Nasim Khaliqhey
dannyvanneijenhoff
- Has thanked: 17 times
- Been thanked: 10 times
Re: losing manu MENU BAR Buttons
Losing MENU BAR, menu buttons, ...
I had the same problem in FC 7.1.1.0, but this easy solution works fine.
I was playing with the "bars", and suddenly, the menu bar was missing. And only visible when opens FC7, and disappear when i open an file.
It cost me only some time, to find this solution. Because i did not know, where (which "name" ) to search.
Perhaps u can change the subject name
