I own Flowcode 7 "emergency FOR COMMERCIAL USE".
I chose the "CHIP KIT Uno32 PICKIT" Board.
After I compiled the program, folowing error message occurs:
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic32\bin\xc32-gcc.exe -mprocessor=32MX320F128H -O1 -o Flowcode1.out Flowcode1.c
C:\Program Files (x86)\Flowcode 7\compilers\pic32\bin\xc32-bin2hex.exe "C:\PRCBF8~1\UNO32\Flowcode1.out"
Launching the programmer...
C:\Program Files (x86)\Microchip\MPLABX\v3.30\mplab_ipe\ipecmd.exe /P32MX320F128H /F"C:\PRCBF8~1\UNO32\Flowcode1.hex" /TPPK3 /M /OL
ERROR: GetShortPathName(): Das System kann den angegebenen Pfad nicht finden.
ERROR: Can not launch process: Das System kann den angegebenen Pfad nicht finden.
C:\Program Files (x86)\Microchip\MPLABX\v3.30\mplab_ipe\ipecmd.exe reported error code -1
FINISHED
What should I do so that the error does not occur
Error with "CHIP KIT Uno32 PICKIT" Board
Pascal_2016
- Been thanked: 4 times
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: Error with "CHIP KIT Uno32 PICKIT" Board
Please if possible post the project you are trying to compile that would help us to try and locate your problem
The chip compiles fine with me it looks to me something is wrong with your paths
- 1.JPG (26.51 KiB) Viewed 5596 times
Regards QMESAR
Regards QMESAR
Pascal_2016
my project see attachment.
I haven't changed the path. This are the standard adjustment.
- Flowcode3.fcfx
- (4.86 KiB) Downloaded 250 times
The problem is the programming, it uses an external tool from Microchip called IPE which is part of MPLABX. You need MPLABX to be installed and the path to be correct for your installation.
http://www.flowcode.co.uk/wikiv7/index.p ... _.28NEW.29
Once you have installed the latest MPLABX check that the path to MPLABX is correct, or simply find release 3.30 from the microchip website as we know this works well and the path is already correct.
e.g. - C:\Program Files (x86)\Microchip\MPLABX\v3.30
You can download version 3.30 of MPLABX from this link.
http://ww1.microchip.com/downloads/en/D ... taller.exe
You can find more information here on how to set this up.Launching the programmer...
Pascal_2016
I have installed MPLAB X 3.30.
Now I have the error message "Programmer not found."
What I did wrong?
The completely error message:
C:\Program Files (x86)\Flowcode 7\compilers\pic32\bin\xc32-gcc.exe -mprocessor=32MX320F128H -O1 -o Flowcode3.out Flowcode3.c
C:\Program Files (x86)\Flowcode 7\compilers\pic32\bin\xc32-bin2hex.exe "C:\PRCBF8~1\UNO32\Flowcode3.out"
C:\Program Files (x86)\Microchip\MPLABX\v3.30\mplab_ipe\ipecmd.exe /P32MX320F128H /F"C:\PRCBF8~1\UNO32\Flowcode3.hex" /TPPK3 /M /OL
C:\Program Files (x86)\Microchip\MPLABX\v3.30\mplab_ipe\ipecmd.exe reported error code 9
FINISHED
What I did wrong?
FINISHED
Aha sorry, we use the MPLABX IPE to program the ChipKit hardware using the PICKIT3 programmer.
The "Programmer not found" message is saying it can't find a connected PICKIT 3.
The CHIPkit hardware does feature a bootloader so I am going to try and tackle the AVRdude command line options this week so we can program without needing the PICkit.
I've tried previously and failed but it's officially on my to do list for this week so hopefully I'll have more success.
I have now posted some new files here on how to program a ChipKit using the standard USB Bootloader.
http://www.flowcode.co.uk/mmforums/viewt ... 63&t=18330
