Error with "Proporties output"
Pascal_2016
Been thanked: 4 times
Post by Pascal_2016 »
I own Flowcode 7 "emergency for commercial use"
The microcontroller is 32MX250F128D
I want in the Proporties output: select the Port RC8, RB15, and RA8
Unfortunately, only the outputs of RA0 - RA3, RB0 - RB3 and RC0 - RC3 be me offered
What should I do, so that my output's can select
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Error with "Proporties output"
Post by QMESAR »
Pascal_2016 wrote:I want in the Proporties output: select the Port RC8, RB15, and RA8
It is possible to what you need,
The PORTS are grouped in PORTx0 ,1,2 ect
This for RB15 you need to select PORTB1 bit 7 and RC8 you need to select PORTC1 bit 0 RA8 I will leave for you to try :D
Attached a sample of your pin setup you can use this project,you just need to set the Configuration in the Project Configuration window under Build>> Project settings
Example Ports.fcfx
(6.84 KiB) Downloaded 229 times
