We have systematical the error code 24 when i want to compile to chip with pickit2.
COMPILER Location:
$(appdir)compilers\pic\bin\xc8.exe
COMPILER Parameters:
--chip=$(chip) "$(target).c" --MSGDISABLE=359,1273,1388
LINKER / ASSEMBLER Location:
$(appdir)tools\DoNothing\DoNothing.exe
LINKER / ASSEMBLER Parameters:
***empty***
PROGRAMMER Location:
$(appdir)tools\PICkit2\pk2cmd.exe
PROGRAMMER Parameters:
-B $(appdir)tools\PICkit2\-PPIC $(chip:u) -F$(target).hex -M -A5 -R
THANKS
Flowcode 7 and Pickit2
lavomatique
Re: Flowcode 7 and Pickit2
Please can you make sure there is a space between PICkit2\ and -PPIC.
e.g.
-B $(appdir)tools\PICkit2\ -PPIC $(chip:u) -F$(target).hex -M -A5 -R
If this doesn't work then you could also try this.
-B "$(appdir)tools\PICkit2\" -PPIC $(chip:u) -F$(target).hex -M -A5 -R
Let us know how you get on.
e.g.
lavomatique
hello.
After having tried yours command line (-B "$(appdir)tools\PICkit2\" -PPIC $(chip:u) -F$(target).hex -M -A5 -R), we have the same problem.
thank.
thank.
lavomatique
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
You can always use MPLab (8 or X), import the hex or cof file (file menu, import) and program that way.
― C.S. Lewis
― C.S. Lewis
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Can you please provide a screenshot of the error in the "compiler messages" window like you did before so we can see what Flowcode is showing.lavomatique wrote:hello.
thank.
lavomatique
I don't understand your question.
see the file to compiler option.
- pickit2.FCS
- (605 Bytes) Downloaded 330 times
