Compilation error
A forums to allow resolved bugs and problems with Flowcode v7 to be stored and marked as resolved.
eduardo.neto
Compilation error
Post by eduardo.neto »
I am getting the following message on compilation:
error.tif
(78.43 KiB) Downloaded 615 times
And this is the file.
TESTE.fcfx
(6.03 KiB) Downloaded 529 times
thank you.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Compilation error
Post by kersing »
That is a notice you can safely ignore. It means Microchip knows there is an error in the silicon (controller chip) and have a software work-around which the compiler automatically applies to make sure your code does not suffer ill effects from the bug.
― C.S. Lewis
eduardo.neto
Thank you Kersing.
