RS232 eblock unexpected charactors?
Chris_MIRA
Has thanked: 2 times
Been thanked: 21 times
Post by Chris_MIRA »
In FC7, Im using the eblocks CAN and RS232 modules to make a translator for communication between two pieces of kit (see HiUCV FC 7 file attached). The programme works BUT the RS232 messages outputted from the eblock have extra characters attached (see Screenshot), the extra characters being !<SYN>T. Unfortunately these characters mess up the kit receiving the message so I need to remove them. I think they are being added automatically as some sort of synchronisation but have no clue how to resolve / stop them. Please help!! :-)
Chris
(124.22 KiB) Downloaded 878 times
HiUCV Loadbank.fcfx
(22.58 KiB) Downloaded 251 times
Has thanked: 481 times
Been thanked: 699 times
Re: RS232 eblock unexpected charactors?
Hi Chris,
Have you attached the correct project? I don't see any UART or output
Leigh
Chris_MIRA
Oops... sorry, to many programs on the same project, the attached file is the one with the RS232 stuff!
Chris
PSU DRIVER Chris L.fcfx
(38.37 KiB) Downloaded 244 times
Hi Chris,
This is probably due to our string concatenation not liking more than two strings.
Could you try changing this ...
Vmax_serial = "SOUR:VOLT " + ToString$ (Vout_Max) + "\r"
To something like this ...
Vout_Max_Str = ToString$ (Vout_Max)
Vmax_serial = "SOUR:VOLT " + Vout_Max_Str
Vmax_serial =  Vmax_serial + "\r"
There has been some work in this area recently by our team on V7, so hopefully this won't be needed once the update is released.
Leigh
Chris_MIRA
thank you for the fast response, Ill go-try it and will let you know :-)
regards,
Chris
