I'll try to explain what I want.
at the start of the program I want to auto search for i2s address and store the result in EEprom. So far all good. (here I have lcd_I2C1 as a dummy to be able to find a addreses).
Here comes the problem.
I now want to start the lcd_I2C2 component with LCD Address from eeprom. This I can not find out how to do.
is there anyone who can help me with this?
https://dl.dropboxusercontent.com/u/209 ... anner.fcfx
LCD (i2c) component. is this possible?
kennethnilsen69
- Been thanked: 14 times
Re: LCD (i2c) component. is this possible?
I have looked at the component source, there is a SetI2CAddress macro but it had not been exposed in the component.
So I have now exposed the macro for you and you should be able to access it by copying the file below to your "Flowcode 6/Components" folder and restarting Flowcode.
The Set Address macro must be called before you call the Start macro.
Let us know how you get on.
Here is the same fix done for v7,
kennethnilsen69
Thanks Benj
this worked perfectly
Benj wrote:Hello,
Hi Benj,
I use a Flowcode 5, here I have a LCD I2C, cant find an address.
Maybe u have component file of LCD I2C to Flowcode 5.
I tried to program on Flowcode 6 but it works (show on LCD) on simulation, on hardware doesn't work.
Please help
Please help
- Lcd_i2c_on flowcode6.fcfx
- my proj
- (5.17 KiB) Downloaded 440 times
Have you tried other addresses than 27?
