Clock 40 Mega or 80 Mega, need help to config it correct
Has thanked: 182 times
Been thanked: 179 times
I use a PIC32MX440F256H.
In the datasheet is wroten 80 Mega but in FC7 is only possible to choose until 40Mega.
So I need a litle help to config it.
I have a 8Mega Quarz on the osci pin.
Is my 80Mega config correct?
run at 80Mega
(54.01 KiB) Downloaded 778 times
run at 40Mega
(50.36 KiB) Downloaded 778 times
Info max speed
(157.5 KiB) Downloaded 2759 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Clock 40 Mega or 80 Mega, need help to config it correct
Post by kersing »
You can enter any clock value you want in the property. Just use your keyboard to enter the value in stead of the drop down box.
― C.S. Lewis
Hi Kersing
Thank you for the fast reply.
I did but the FC dont accept 80Mega. See in the attachment.
(17.29 KiB) Downloaded 2752 times
kersing
Post by kersing »
That looks like an issue in the device definition file. I'll move this message to the appropriate sub forum.
― C.S. Lewis
Thanks for letting us know,
For some reason all the other devices in the family are defined correctly, it's just this device that has the problem.
Here is an updated definition file you can use. Simply copy the file into your "Flowcode 7/FCD/PIC32" folder and restart Flowcode to load the changes.
32MX440F256H.fcdx
(39.51 KiB) Downloaded 320 times
