Hi!
I am making a project with an Eico 40. Unfortunately I am not able to program it. I have dowloaded and install the USBdrivers for Eico. I can't even see when I plug in an Eico in devicemanager. I have not used Eico since win7. Could it have something to do with win10??
Doesn´t work on FC5 6 and 7
I run win10
32 bit
Please
Br Jorgen
Eico28 - 40! SOLVED!
- Has thanked: 1135 times
- Been thanked: 299 times
EtsDriver
- Has thanked: 345 times
- Been thanked: 227 times
Re: Eico28 - 40!
Did you install the digitally signed drivers from forums?
What kind of ECIO you are trying to use, the 8-bit PIC one, dspic etc?
Steve001
- Has thanked: 460 times
- Been thanked: 523 times
Re: Eico28 - 40!
hi
as ets driver mentioned have you installed the signed drivers (I had to install these to get mine to work )
You have to install the driver prior to plugging in your ecio device
Re: Eico28 - 40!
Hi both!
Thank´s for reply!
I have done as you recomended, but still no luck.
I have done it on two labtop. I If I go in device manager the USB for Eico is not seen or reconized.
Any good idea I could try.
Br Jorgen
Thank´s for reply!
Br Jorgen
Re: Eico28 - 40!
Hi Both!
OOPPss! My fault. Sorry for the inconvenience. Embarrassing.
The jumper on the Eico was placed in EXT and not in USB. As soon I jump it in USB, it work immediately.
Thank´s for help and troubleshooting.
Br Jorgen
Br Jorgen
