PWM LED Control
Zalat88
Has thanked: 2 times
PWM LED Control
Post by Zalat88 »
Hi everybody.
I have a problem with PWM.
I want to control the brightness of LED with one button and PWM. For example: when I push a button for a 3 sec.Led should be smoothly light, else when I push fast for 1 ms LED should light instantly,
maybe someone can help me??
Re: PWM LED Control
Hi Zalat,
I have split your post onto a new thread so it doesn't hijack the last topic.
Have you had a go at the problem yourself? If you post your code so far then we can help suggest ways to improve of fix things.
You don't state what hardware you're using i.e. which chip.
Zalat88
Re: PWM LED Control
Post by Zalat88 »
Hello Mr.Benj
thanks for reply
ok, I'll put my project
I use atmega 328p
Zalat88
Re: PWM LED Control
Post by Zalat88 »
Zalat88 wrote:Hello Mr.Benj
thanks for reply
I use atmega 328p
PWM_BUTTON_328.fcf_avr
(15.63 KiB) Downloaded 351 times
Re: PWM LED Control
Here you go, This should allow you to switch the LED on and off with ramp up and ramp down while the switch is held.
PWM_BUTTON_328_v7.fcfx
(10.94 KiB) Downloaded 391 times
You may find the LED reaches full brightness around 50% duty. To help give a better range you could lower your PWM frequency (which may help somewhat but could lead to noticeable flicker) or you could increase the delay in the loop.
To save power you could make 128 the new maximum duty value e.g. the LED looks just as bright but actually it's off for half of the time saving 50% power.
