Bug with I2C
Pascal_2016
- Been thanked: 4 times
Bug with I2C
CPU 32MS150
My config settings are as follows:
#pragma config FNOSC = FRCPLL
#pragma config FPLLIDIV = DIV_2
#pragma config FPLLMUL = MUL_20
#pragma config FPLLODIV = DIV_2
#pragma config FPBDIV = DIV_1
#pragma config DEBUG = OFF
#define GetSystemClock() (40000000ul)
#define GetPeripheralClock() (GetSystemClock())
#include <plib.h>
I have a EEPROM wiht I2C Bus. In this EEPROM I will write or read from.
With the programme in the annex, I want to write in the EEPROM or read from the EEPROM. I could read and write to the EEPROM in Flowcode 6
The same program was not run in Flowcode 7. What should I do so I can get the same result in Flowcode 7.
CPU 32MS150
#include <plib.h>
- TestI2C_Bug_Report.fcfx
- (72.75 KiB) Downloaded 340 times
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: Bug with I2C
Hello;
I do not know of any 32MS150 devices however assuming you use a MX150 then according to the datasheet if you are using the FRC with communications such as SPI,I2C which requires as certain accuracy you should adjust the OSCTUN regsiter ,I myself never use FRC's but it may be worthwhile to check this out from your-side
I did not check your Flowchart so if you are doing this then I apologize for saying it
- 1.JPG (32.15 KiB) Viewed 9251 times
Regards QMESAR
Regards QMESAR
- QMESAR
Re: Bug with I2C
Hi I looked at you flowchart and I am just asking what is the reason/ benefit that you use the standard #pragma directives to initialize your clock settings and not the provided Config tab in FC as you set your frequency in C code but in FC Config you have Clock setting of 20Mhz that in my opinion once you use Components that rely on this value to setup the modules / components will be incorrect as the mcu is running one speed and you are telling FC it running another speed you should setup the basics in FC correctly before saying there is a bug
Your Config seems to be for 40 MHZ you tell FC it is 20 MHZ this way you are doing it seems to me away to allow errors to creep in which can cause you to loose a lot of time
just my opinion
just my opinion
- 2.JPG (82.46 KiB) Viewed 9235 times
- 1.JPG (58.77 KiB) Viewed 9235 times
Regards QMESAR
Regards QMESAR
Pascal_2016
Re: Bug with I2C
yes, my Microcontroler is 32MX150.
The matrix configuration I have switched off because I no DIN A5 page warnings will read to detect that the program without error created the hex file.
Why I use 20 MHz, can You read in the entry "32MS150 oscillator failure".
Sorry Your answer was not helpfull
- QMESAR
Re: Bug with I2C
I am sorry it did not help you however I still think you are missing what the setting in the config are doing specially the value of the ClockSorry Your answer was not helpfull
lets leave it there
Regards QMESAR
Regards QMESAR
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Bug with I2C
To determine if the problem is with the clock speed, you could create a simple LED flasher circuit which blinks an LED at a set rate (e.g. each second)
loop forever
output on
delay 500ms
output off
delay 500ms
end loop-
Pascal_2016
Re: Bug with I2C
The error has nothing to do with the clock, because as you can see in the flow diagram, I have installed a 1.0 Hz clock. The clock frequency is exactly 1 Hz.
Re: Bug with I2C
QMESAR is right the comment you have at the top of your Main flowchart doesn't match the values in the Project Options -> Configuration.
Here is some helpful tips to getting things running at the right speed.
http://www.flowcode.co.uk/wikiv7/index.p ... ED_flasher
Do you need a delay near the start of your program to allow the I2C slave device time to power on?
Pascal_2016
Re: Bug with I2C
If the 32MX150 has clock problems, why can I measure at pin CLKO 40 MHz and why blinking the LEDs in the 1 second intervals? Why did the 1Hz LED flasher circuit blinking at 40 MHz with 0.5 Hz and at 20 MHz with 1,0 Hz?
The microcontroler shows the same behavior in this configuration
#pragma config IOL1WAY = 0
#pragma config FUSBIDIO = 1
#pragma config FVBUSONIO = 0
#pragma config FPLLIDIV = 1
#pragma config FPLLMUL = 5
#pragma config FPLLODIV = 1
#pragma config FNOSC = 1
#pragma config FSOSCEN = 0
#pragma config IESO = 0
#pragma config POSCMOD = 3
#pragma config OSCIOFNC = 1
#pragma config FPBDIV = 0
#pragma config FCKSM = 3
#pragma config WDTPS = 0
#pragma config WINDIS = 0
#pragma config FWDTEN = 0
#pragma config FWDTWINSZ = 0
#pragma config DEBUG = 2
#pragma config JTAGEN = 0
#pragma config ICESEL = 0
#pragma config PWP = 0
#pragma config BWP = 1
#pragma config CP = 1
Pascal_2016
Re: Bug with I2C
the system clock measured on the CLKO PIN is 20 MHz and the LED clock is 1 Hz. The issue isn't the configuration. The issue is the implementation of I2C. The SDA have only one square wave not more and no signal at SCL PIN.
EtsDriver
- Has thanked: 345 times
- Been thanked: 227 times
Re: Bug with I2C
Try this out...
- 40M clock set
- (72.77 KiB) Downloaded 278 times
Pascal_2016
Re: Bug with I2C
Thanks for the example. Unfortunately, this example could not fix the problem.
The frequency on CLKO Pin is 8 MHz.
The Lamp clock is 0.21 Hz
I have adapted my configuration settings on the clock frequency of Flowcode.
FPLLIDIV => 2x Divider --
FPLLMUL => 17x Multiplier | => 34 MHz
FPLLODIV => 1x Divider --
FPBDIV => Sys_Clk/2
Unfortunately is the I2C interface not running also with this setting
FPBDIV => Sys_Clk/2
