Is this a Bug or i am doing somthing wrong ? , I have 2 files in the SD Card named
A.txt and B.txt, A.txt contain " This is File A " and B.txt contain " This is File B "
In the flowchart I : INIT CARD -> SetFileIndex(0) -> OpenFile(A.txt) - > SetFileIndex(1) -> OpenFile(B.txt) - > ReadStringFromFile(50,13)
-> SendString via RS232 -> SetFileIndex(0) -> ReadStringFromFile(50,13) -> SendString via RS232
I get the below result :
This is File B
This is File B
FAT Set File INDEX [solved]
- B.txt
- (45 Bytes) Downloaded 286 times
- A.txt
- (47 Bytes) Downloaded 266 times
- Flowcode1.fcfx
- (9.79 KiB) Downloaded 275 times
Re: FAT Set File INDEX
Hi Alan,
I think I see what's going wrong. The buffer is not being reloaded when you change the file index so the data is coming from the FileB buffer.
How about trying this instead.
-> SendString via RS232 -> SetFileIndex(0) -> ReadFileSector() -> ReadStringFromFile(50,13) -> SendString via RS232
Hi Benj
Thanks for your reply
I have added the ReadFileSector() but i am still getting the same result .
- (15.49 KiB) Downloaded 2608 times
- Flowcode1.fcfx
- (9.96 KiB) Downloaded 288 times
Hi Alan,
In the FAT component properties the Max Concurrent Files property is set to 1, if you change this to 2 does this make any difference?
Hi Benj
Yes that was the problem , now it is working fine , i must have missed that setting
can move this to general programming as it was not a bug .
Thanks very much for your support .
Great news, thanks for letting us know.
