E076 card recorder [solved]
Anastasiia
Post by Anastasiia »
The E-block card reader don't work. How I could check is it problem in E076 or I did something wrong in flowcode? I use flowcode macro initialiseCard.
Re: E076 card recorder
Sorry to hear you're having problems. Please can you post your program so we can see your chip configuration settings etc.
Have you been able to get anything to appear on the display?
Anastasiia
The touch screen work. It is only the card recorder problem.
Thank you
project.fcfx
(14.79 KiB) Downloaded 368 times
Many thanks for the file.
I think I have now found and fixed the bug with the card initialise function.
Here is an updated component for you to try. The file lives in the "Flowcode 7/components" folder. Copy the file and then restart Flowcode for the changes to be loaded.
gLCD_EB076v2_4D.fcpx
(28.96 KiB) Downloaded 372 times
Let me know how you get on.
Anastasiia
Sorry, but now I see nothing on display (only white sheet)
Thanks for letting me know.
I was checking to see if the card was inserted and initialising but I wasn't mounting the card ready for FAT filesystem access.
Hopefully the attached should work better.
(29.05 KiB) Downloaded 412 times
Anastasiia
Great thanks. Now card reader works.
