I would really appreciate any help.
I am trying to generate a square wave signal of 2ms (on/off) using a 12F683. I have a very simple flowchart that only varies the pulse between signals. I need to be able to generate from 1 hz to 300hz only.
I have and ADC on pin 7 of the pic and use that to vary the delay
It works fine on lower frequencies but I find that there are large jumps in the frequency when I approach 200hz.
Here is my flowchart....
I'm sure there is a better way to do it but have racked my brain and not been able to come up with anything better.
Conroy
Signal gen using 12F683
Re: Signal gen using 12F683
The way I would do his is to use a timer interrupt running much faster than maximum frequency which will allow better control.
For example for max of 300Hz i would set the timer interrupt at about 6KHz.
Next I would add a variable that counts 1 every time interrupt macro is accessed.
E.g TimerTick = TimerTick + 1
then I would work out how many time the interrupt has to be accessed for 2 x min frequency and 2x max frequency.
For 2 x min frequency: : Note got into my mind min - 2Hz. only when re-read noticed 1Hz
For 2 x max frequency:
Reason for twice frequency is after correct time has elapsed then output is toggled to produce a perfect square wave.
I would then create a calculation to produce 10 when ADC = 0 & 1500 when ADC = 255
E.g
Within interrupt macro I would have:
Note: is NOT equal so output is changed from 0 to 1 then 1 to 0 each time is accessed.
finally within decision brance place
Below the decision (so its not a part of it),just place an output:
6000/(2 x 2) = 1500For 2 x max frequency:
6000 (300 x 2)/ 6000 = 10I would then create a calculation to produce 10 when ADC = 0 & 1500 when ADC = 255
E.g
Delay = ADC * 146 / 25 + 10Code: Select all
If TimerTick >= DelayCode: Select all
EnableOutput = !EnableOutputCode: Select all
=! finally within decision brance place
TimerTick = 0Code: Select all
EnableOutput>A4Martin
To make life easier, you can use timer2 interrupt.
To help you set it to 6KHz, there is a great app posted on these forums.
It produced best settings very quickly.
If you need further help then let me know.
