CCP on 12F1822
conroydp
Been thanked: 3 times
CCP on 12F1822
Post by conroydp »
Hi Martin,
Tx again for your quick and very helpful response, much appreciated.
I have developed another flowchart which will assist in counting the interrupts on RA2 and provide an output using CCP1. Unfortunately, the INT and CCP are both on pin5.
I noticed that flowcode does not allow me to "Use alternative pin"
I then resorted to setting "apfcon=0x01;" in a "C-code" block. According to the datasheet, this should move CCP to RA5, however it does not appear as if I am getting an output on RA5.
I found a few posts relating to Alternative CCP not working, but nothing related to the 12F1822.
I would appreciate it if you could advise as to any known bugs/workarounds.
Conroy
12F1822 CCP.fcf
(16 KiB) Downloaded 554 times
Re: CCP on 12F1822
Hi Conroy,
You might need to make pin A5 be an output before enabling the PWM (CCP), e.g. using an output icon in single bit mode.
Hopefully this will allow it to work as expected.
conroydp
Re: CCP on 12F1822
Post by conroydp »
Hi Benji,
I added an output for RA5. Now I am getting the PWM signal on both pins (RA2 and RA5).
Any suggestions?
Conroy
