For anyone wanting to use a PIC32 ChipKit I have some good news.
We have looked a few times at supporting the ChipKit bootloader and failed. Now I am happy to announce we have finally cracked it.
I have included this fix in the files here: http://www.flowcode.co.uk/mmforums/viewt ... 63&t=18209
If you have an existing project then remember to change the target to the Bootloader version of the chip.
Also remember to select the correct COM port.
This fix should also resolve the spaces in project filename compilation errors.
If you need to restore the Bootloader to your ChipKit then you can do so using a PICkit 3 and the MPLABX IPE software, the bootloader hex file can be found from this page.
http://chipkit.net/wiki/index.php?title=Boards
Chipkit + Bootloader Programming
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: Chipkit + Bootloader Programming
Thank you very much B
en and Team this is great news for many users
Regards QMESAR
Regards QMESAR
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
I've added your new components but I'm not able to get the board to program
C:\Program Files (x86)\Matrix TSL\Flowcode V7\compilers\pic32\bin\xc32-gcc.exe reported error code 255
After pressing compile to chip the window goes blank and shows the above message
I have reloaded the bootloader into my chipkit board using the pickit3 and mplab, as I have previously programmed it with the pickit
- QMESAR
As John I have reprogrammed my uc32 with the boot loader and when pressing compile to chip in FC, I get the same error
Regards QMESAR
Regards QMESAR
Hi Guys,
Thanks for letting me know. I have now fixed the broken file on the link below and it should now work correctly.
- QMESAR
Updated my FC with the new files from the link however when programming then I get the following error message
I aslo do not locate such a file in my system
do not know if this is a path problemC:\Program Files (x86)\Flowcode 7\compilers\pic32\bin\pic32prog.exe reported error code -1
- 1.JPG (34.31 KiB) Viewed 8628 times
Regards QMESAR
Regards QMESAR
Please can you try the update again I've added the programmer executable now and it hopefully should all work this time.
- QMESAR
Sorry for this post I did not see the one from John and when I did I downloaded the new files ,
The update is working fine with me
Thank you very much
Thank you very much
- 1.JPG (42.36 KiB) Viewed 8611 times
Regards QMESAR
Regards QMESAR
Jacob Christ
How exactly does this work? It seems like your replacing the bootloader on the board. So you would need a custom bootloader for each chipKIT board, correct?
We make the PONTECH Quick240 (pontech.com / quick240.com) which was based on the chipKIT Max32 but we have a modified bootloader.
Jacob
Jacob
