WS2812 Compiler Error
ressi
Been thanked: 14 times
Post by ressi »
Can you Help me with this Problem? I have a 18F46K22 with 64Mhz and have this Error.
I have a Flowcode 7 Pro Lizenz.
AnimLightStrip2.fcfx
(9.01 KiB) Downloaded 265 times
(36.52 KiB) Downloaded 568 times
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: WS2812 Compiler Error
Post by QMESAR »
Hi ;
Try to switch of the extended instruction set as below go build >> Project options >> configuration
:D
ressi
Post by ressi »
Hello. Thanke for the tip, the error is gone. The other error is still there, and the program does not work in the PIC. Does the WS2812 work with an 8-bit controller?
(58.28 KiB) Downloaded 543 times
It should work with an 8-bit PIC running at 64MHz.
There is a speed improvement for the WS2812B component on PIC devices included here which may help allow things to run correctly.
http://www.flowcode.co.uk/mmforums/viewt ... 63&t=18209
Let us know how you get on.
ressi
Post by ressi »
Hello. Thank you for the link. After the installation it runs however not quite correctly. I change the LED controller to AP104 - it runs great. THANK YOU.
@Benj: I found the scrolling RGB Message Board, from you.
Can you post the Flowchart? I could learn a lot about text scroll ! https://www.youtube.com/watch?v=mRU2dgJ-EYs
i want to scroll a Text with MAX7219 but i dont know how. With your Flowchart i can learn a lot.
THANKS for HELP
