Hi all .
Using a spi component from the cal library results in compilation errors some missing definitions it looks like
Error PIC32 cal_spi Component
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
- 1.JPG (50.15 KiB) Viewed 4114 times
- 2.JPG (33.05 KiB) Viewed 4114 times
Regards QMESAR
Regards QMESAR
Re: Error PIC32 cal_spi Component
Thanks for letting us know, can you tell me which device your using or post a program that demonstrates the problem?
- QMESAR
It is a PIC32MX250F128B attached is a project that shows this
- makeMakro.zip
- (26.79 KiB) Downloaded 243 times
Regards QMESAR
Regards QMESAR
Many thanks here is an updated CAL file that should solve the problem.
The file needs to be placed into the "Flowcode 7\CAL\PIC32BIT" directory.
- QMESAR
Thank you very much Ben
Regards QMESAR
Regards QMESAR
