Error Programming with Ghost enabled
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi All ,
I am having problems to work with my Flowkit V2 and PIC32MX250F128B
When I compile and down load the Hex to my target and then enable the ICT I can see the traces from Flowkit on the pins enabled no issues here however when I enable ICD and compile to chip all goes well till the last checks FC does after programming then it reports ICD error ,
I am just not able to use the ICD so far I use D8 as Data(PGD) and D9 as Clock(PGC) as indicated by FC What is the meaning of this error code 1 ? :D
Then also I have an LED conected to pin RB13 however in the ICT configuration under Digitals I am only able to select RB7 as it is the maximum number showed ,is this correct ,I then did select RB7 but put the D0 probe on RB13 it shows me the trace
I would have expected that I can select for D0 the RB13 ?? ,This is confusing as the trace name and the real pin has no relation :D
Thank you for the help as always
Has thanked: 481 times
Been thanked: 699 times
Re: Error Programming with Ghost enabled
Thanks. Looks like we have some work to do first thing on Monday. :D
QMESAR
Post by QMESAR »
Thanks LeighM That will be appreciated :D
QMESAR
Post by QMESAR »
Hi Team,
Due to the fact that I have to deliver a SW package and with the bugs present with the PIC32MX250 I am forced to run a PIC18 and now the Ghost and Flowkit V2 on PIC18F2585 seems to have a problem too or is it simply me not understanding how to work with the Flowkit!
Here is my procedure please advise if I am doing something wrong !
(1) I make my Flowchart
(2) I have my PICKIT connected to the device
(3) I have Flowkit Connected also to the device D9 >> PGC on PIC18 it is pin RB6 and D8 >> PGD this is pin RB7
(4) I enable Ghost the icons turn green ,I enable Allow step through Icons(checked the check box)
(5) I now compile to chip
(6) FC compile start the IPE and program the device (No errors reported as by PIC32)
(7) I press the green run Icon in FC then the following error dialog pops up
Please help I have a customer target date to meet :D
Could you try disconnecting the PicKit from your device before running Ghost
QMESAR
Post by QMESAR »
LeighM wrote:Could you try disconnecting the PicKit from your device before running Ghost
I did that a few times as I also thought it is the PICkit that interfere with the Flowkit however that makes no difference :D
As for your original issues on PIC32:
1) The ICD download error. We will try to replicate this on some PIC32 hardware.
2) The ICD dialog inability to select pins above 7 is a Flowcode issue which I have now logged with the executable team.
QMESAR
Post by QMESAR »
LeighM wrote:As for your original issues on PIC32:
LeighM Thank you very much ,what is the situation with PIC18 and Flowkit ? Is there a chance for a solution soon or is this also going to take some time I am asking if it is the case then I have to revert back MPLAB for this as I have a deadline to meet :D
Regarding the PIC32 and ICD, I wonder if the problem is related to Flowcode needing a .cof file to decode the global variable addresses.
Currently a coff file is being generated but it is given the default name .out instead of .cof.
You can try changing the compiler options to try and fix this.
Compiler Parameters.
-mprocessor=$(chip) -O1 -o "$(srcdir)$(target).cof" "$(srcdir)$(target).c"
Linker Parameters.
Hopefully this will make a difference. Let me know how you get on.
PIC18 and Flowkit should be OK, I currently have a setup running.
Could you try resetting the target device each time before you Run or Step ICD?
QMESAR
Post by QMESAR »
Thank you for the advise :D unfortunately with Ghost enabled and compiling to chip with these compiler settings FC crash after it programmed ,then I only disable Ghost with the same settings then it compiles and program the device it also reports that a .COF file was generated :(
QMESAR
Post by QMESAR »
LeighM wrote:PIC18 and Flowkit should be OK, I currently have a setup running.
I believe that it is running with you however with me it not running :D
I did the following
(1) enable Ghost
(2) Compile to hip
(3) reset the device with the Reset button on MCLR (Pin 1pulled down when button pressed) aslo did a hard reset by removing the supply
(4) remove the PicKit
Run Ghost every time results in the error shown below
Looks like the XC32 default COF is not the correct .coff file format for Flowcode which is causing the crash.
I'll investigate how to generate the coff file in the right format to keep Flowcode happy. The coff file is used to determine variable addresses for ICD.
Re the 18F and FlowKit problem, I'm stuck for suggestions, other than perhaps checking the Gnd, Clock and Data connections?
QMESAR
Post by QMESAR »
Thank you Ben much appreciated
QMESAR
Post by QMESAR »
Thank you for trying to help :D I am not sure what this is or what happened I was programming and resetting the device many times and it would not connect then I was trying again and again and then it started to communicate
any case It is now working
just one of those mysterious things
I have question if I place a break point inside the main then the debugger will stop at the break point ,when I place a break point in a makro then it will execute the makro but does not stop at the break point in the makro is this normal
appreciate your feedback as in the screen shot the breakpoint is in side a makro and not in the main loop it does not stop at the break point
Thanks, that does sound like a bug that has crept in.
The Flowcode Ghost code is currently being re-written in readiness for an update release early next year.
So that's good news and bad news in that, sorry, it's very unlikely that this bug will get attention in the current code base.
QMESAR
Post by QMESAR »
Thanks for the info that is fine I can live with the bug :D till next year
