Hi Team
using Ghost and dsPic30F when pressing the Ghost Run button Flowcode crash don`'t know may be it is the same issue as with PIC32 that Ben mentioned regarding the
.cof file .
hope these issue will be solved soon
FlowCode Crash when using Flowkit V2 with dsPIC30F
Re: FlowCode Crash when using Flowkit V2 with dsPIC30F
I think this problem may already be fixed. Please can you extract the attached files to your "Flowcode 7\compilers\pic16\batchfiles" directory.
Hopefully then the crash should be resolved, at least on 16-bit PIC devices.
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Thank you very much that has solved the crash issue
Just to inform you the Pins that is shown for the ICD incorrect it should be RF2 and RF3 for PGC and PGD
- 1.JPG (27.77 KiB) Viewed 3002 times
Regards QMESAR
Regards QMESAR
