Hello Team.
I received a new EB006V9 from you guys and I installed the drivers as per your manual and when I select ghost then the hardware is found however when I Compile to chip (Ghost not enabled) all go well until mloader is called Mloader opens and report it does not find a device ,it also ask to reset I do this but the device is never found ,
I then changed to my PicKit 3 (changed the jumpers) and I program the device from FC with no problem )
What I did I check that Vdd and Vss are present on the chip pins and Also MCLR is pulled up I see no reason hardware wise why mLoader does not find the device
Any ideas what could be the problem or what I can do to solve the problem the device is a PIC18F2585
EB006V9 Can not detect device
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
- 1.JPG (32.72 KiB) Viewed 4997 times
Regards QMESAR
Regards QMESAR
