Please help with RXINT0
tiny
Has thanked: 51 times
Been thanked: 93 times
Post by tiny »
I connected a Nextion touch screen to Com Port 1, the display is programmed so that every 5 seconds a query is made for changed data. In order not to reprogram the MCU every time, I have connected the display on the Com Port (USB) of my PC.
Now I want to jump over the serial interrupt into my routine, which performs the matching and provision of the data for the display.
It just does not work, whatever I try.
I am using FC7 7.1.1.0 with all updates.
Perhaps who can help me?
Christina
Uart_Test.fcfx
(12.72 KiB) Downloaded 345 times
ressi
Been thanked: 14 times
Re: Please help with RXINT0
Post by ressi »
Do you already have a working nextion?
I describe my nextion as on the picture and the functioned.
First, I choose pointer (z0) - then the value what it should display (retval) and end the transmission with 3 times send of 255. I do not know whether it goes as you do (Slepp = 0 \ xff \ xff \ xff )
(7.51 KiB) Downloaded 4033 times
ressi
Post by ressi »
And the Default Baud from the Nextion is 9600 you have 38400. https://www.itead.cc/wiki/Nextion_Instruction_Set, baud /Current value of baud /1.baud=2400 2.baud=4800 3.baud=9600
4.baud=19200 5.baud=38400 6.baud=57600 7.baud=115200
tiny
Post by tiny »
The baud rate works with Nextion up to 115200. I have set 38400 Bd. With Bauds=38400 the transmission rate is permanently adjusted, runs fine.
Sleep = 0 is needed because I have 3 minutes Auto Sleep.
The 3x \xff \xff \xff are the end signal of a command via the serial interface.
The functions of the display are:
EEprom Parameter setting, display of the switching states and manual switching of the MCU outputs via Nextion Touch symbols.
However, my problem is that the Receive Interrupt is not responding. All other is no problem!
Christina
tiny
Post by tiny »
Perhaps someone can tell me whether in the simulation the Interrupt RXINT0 of the RS232 interface with Injector functions. This would be very helpful, I do not know whether I should continue to try to configure the interrupt according to data sheet.
tiny
Post by tiny »
After I got no answer to my post, here again the question in short form:
Does RXINT work in simulation?
Many apologies for the delay in replying.
No the UART RXINT interrupts don't currently work in simulation. To get around this you can either include a call to the RXINT macro in your main loop or you can add a simulation API timer to call the macro for you on a regular basis.
I wonder if we can somehow add a hook to get a call back based interrupt from the PC COM port and injector components. I've made a note to try and investigate this but my guess is it's not an easy fix.
tiny
Post by tiny »
Thank you Benj for the answer! It would really help if this function can be realized. It is much easier to check the routines on the PC under real conditions and then program the MCU.
I will first create a workaround to complete my program.
Christina
