problem comp vs2015 and c++
For Formula AllCode users to discuss projects, programs, and any other issues related to the Formula AllCode robotics platform.
Kjell Holen
Been thanked: 2 times
Post by Kjell Holen »
I have a few question to the setup. I use Windows 10, and visual studio 2015 c++
Want to test c++ and the robot
I assume I do somthing wrong with setupo/ compil. Glads if someone could give some hints,
Have downloaded 2 dif. code example.
Should I use Slave-allcode_examples or FA_CP_Formula Allcode C++ VS2015
I use visual studio c++ 2015. Should I run VSCodeSetup-1.8.0.exe
must the file-tree be: /document/visual studio 2015/
I have tried, but got error.
Startet VS and File Project/solution and brosed to tne Formula AllCode.vcxproj selecdet
got error could not find faslave.lib but the file was there
rgds
Re: problem comp vs2015 and c++
Make sure the FASlave.dll file is in the same directory as the exe file and it should work ok.
FASlave.zip
(11.27 KiB) Downloaded 651 times
You might also need to include the faslave.lib file in the project.
