PICKIT WI-Fire PIC32MZ2048EFG100 200MHz
Has thanked: 182 times
Been thanked: 179 times
I have a Digilent PICKIT WI-Fire PIC32MZ2048EFG100 200MHz
I can program it nice with Flowcode 7 and PICkit3. I can turn on/off the 4 pcs of LEDs on the board.
But I have a problem to configurate the clock correct. If I control the on time from a led it's 2.5 miliSeconds.
As if I can not let the board run on 200Mhz "only" on 80Mhz. (2.5 times slower). Can You help me to configurate it to 200Mhz.
http://store.digilentinc.com/chipkit-wi ... ler-board/
PCB
(507.1 KiB) Downloaded 1312 times
Flowcode1-chipkit-wi-fire-1.fcfx
Demoprogram
(9.11 KiB) Downloaded 403 times
Re: PICKIT WI-Fire PIC32MZ2048EFG100 200MHz
Are you still having problems getting this running at the right rate? I started having a look for you but then got distracted with something else. What configuration options have you tried? I can maybe put together a new definition file for this ChipKit board and that should allow you to program via the built in bootloader and hopefully this will automatically be running at 200MHz.
That's a good idea to use the built in bootloader for this kit.It will help us a lot.
Please send me a new definition file for the kit, if it's ready.
I can test it easy with my osciloscope.
For the clock, I tried many different settings, but the clock was never higher than 80Mhz.
Hi Stefan,
Just putting the definition file together for you. I don't suppose you know the USB VID and PID for the board do you? They can be found in the windows device manager, under the Ports section. These are used for the COM port auto detection but are not strictly necessary.
Right to add the new Wi-FIRE definition you first need to ensure you have applied the latest files from here.
http://www.flowcode.co.uk/mmforums/viewt ... 63&t=18209
Once you have done this you need to add the linker script from this archive. The "MZ-application-32MZ2048ECX.ld" file lives in the "Flowcode 7\compilers\pic32\chipKit" folder.
MZ-application-32MZ2048ECX.zip
(4.13 KiB) Downloaded 414 times
Finally you need the new definition file which lives in the "Flowcode 7\FCD\PIC32" folder.
ChipKIT Wi-FIRE Bootloader.fcdx
(47.59 KiB) Downloaded 380 times
Let me know how you get on.
I did it. I can load the chipkit add my code and compiele it to c.
I can also see the com3 USB serial port in the programmer port option.
But compile it to hex gives problem....
I create a folder "chipKit" and put the "MZ-application-32MZ2048ECX.ld" there
C:\Program Files (x86)\Flowcode 7\compilers\pic32\chipKit
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic32\bin\xc32-gcc.exe -O1 -G1024 -Wl,--gc-sections,-Map,"Flowcode1_usb_Bootloader1.map" -nostartfiles -T "C:\Program Files (x86)\Flowcode 7\compilers\pic32\chipKit\MZ-application-32MZ2048ECX.ld" -T "C:\Program Files (x86)\Flowcode 7\compilers\pic32\chipKit\chipKIT-application-COMMON-MZ.ld" "C:\Program Files (x86)\Flowcode 7\compilers\pic32\chipKit\cpp-startup.S" -mprocessor=32MZ2048EFG100 -o "Flowcode1_usb_Bootloader1.cof" "Flowcode1_usb_Bootloader1.c"
xc32-gcc.exe: error: C:\Program Files (x86)\Flowcode 7\compilers\pic32\chipKit\cpp-startup.S: No such file or directory
Hi Stefan,
Make sure you have done this step as it includes several key files to allow the ChipKIT bootloader programming to function.
Thank you for the remind me.... I have to do this on every computer with F7 .
It's great what you did! It's working nice.
A little bit is not correct in my program. I have delay of 1mSec but the scope shows me 4mSec.
I will test some more signals.
(11.55 KiB) Downloaded 5909 times
There is a small question about the board.
Will the Wifi chip(modul) be supported in the future from FC7.
It's from Microchip
MRF24WG0MA WiFi module
It might be worth toggling an output with a timer interrupt and seeing if that is running at the right speed.
2 things I can think of to cause this.
1) it's not running at 200MHz it's running at 50MHz, seems unlikely as ChipKIT bootloader should have it running at max speed.
2) The core timer we use for timings is running on a /4 pre-scaler on some MZ devices.
To test out option 2 here is a slightly updated CAL file for PIC32, note do not update the file unless your having this issue on a MZ device. This file lives in the "Flowcode 7/CAL/PIC32BIT" folder.
PIC32BIT_CAL_Delay.c
(4.19 KiB) Downloaded 411 times
You should be able to talk to the module now using the SPI component in Flowcode, and of course if you create macros that are useful then you can package these up into your own component.
As for us creating a component to simplify the usage, we can certainly add it to the list to investigate but we have a lot on our plate at the moment.
Thank You for the big help.
I used the new cal_Delay.c
It's correct now. One Second delay in software is on the board one second too.
Unfortunately I tryed to use an IRQ.
In the simulation it's working but if I download it in the chipkit, the software is not running.
And I saw some PIC32 USB folder...... Is Usb now working with pic32?
Flowcode1_usb_Bootloader1.fcfx
simple irq
(10.95 KiB) Downloaded 299 times
I have now FC7.2 and I have the Problem with the IRQ. The program stop if I use an IRQ
