Software uart wont compile
zadah
Has thanked: 3 times
Been thanked: 7 times
Post by zadah »
FC7 software uart wont compile (12f683)
When I open same file on FC6 it compiles ok. (File was orginally made in FC7 free version)
PS. Could you make interface more like in FC5 ( it has most clear layout so far...) + it would be nice to have custom C code like in FC5.
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Software uart wont compile
Post by QMESAR »
zadah wrote:FC7 software uart wont compile (12f683)
Well you can add custom C code in FC 6 and FC 7 or I am misunderstand you some how
zadah
Post by zadah »
I mean c code editable components like in fc5. They disappeared with fc6 which was big loss on terms of functionality of the program.
In v5 this was a fairly nice feature however it was a support nightmare and had the ability to really break your programs with no way of knowing how or why. We purposely removed it from v6 and instead created the component creation feature should you want to create your own component library with different or altered code. This also simulates which is a massive advantage over the v5 none simulating custom code.
For the next upcoming v7 release we have made component creation significantly easier which should help a lot.
Investigating the software UART problem for you now.
I have now fixed the problem. Simply copy the attached file into your "Flowcode 7/CAL/PIC" folder and the compilation should then work correctly.
PIC_CAL_IO.h
(10.94 KiB) Downloaded 344 times
zadah
Post by zadah »
Benj wrote:I have now fixed the problem. Simply copy the attached file into your "Flowcode 7/CAL/PIC" folder and the compilation should then work correctly.
PIC_CAL_IO.h
Thanks Benj, i will give it a try.
