Real time clock DS1307 using I2C
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Post by Jan Lichtenbelt »
(Earlier publications using ds1307 are available in this Forum. Thus, this is not new!)
Learning I2C I found the sample Flowcode I2C_DS1307_Eaxample.fcfx
http://www.flowcode.co.uk/wikiv7/images/ ... rTest.fcfx in the Flowcode help.
It took a while, but find out that it is only a simulation version.
To find out what the problems are using I2C in practice, I build a setup with the 16F1939 (40 pins) microchip and the EB005-006 and 007 boards (LCD, multiprogrammer board and 8-push button switches board) in connection with an DS1307 real time chip with battery backup. SDA (data) is connected to C4 and 4k7 to Vcc and SCL (clock) to C3 and 4k7 to Vcc.
After learning to work with number conversions to BCD, I made a program which can change the clock by means of 3 push buttons B0, B1 and B2:
B0: Start and reset seconds to zero
B1: Increase minutes with one
B2: increase hours with one
With kind regards
Jan Lichtenbelt
DS1307RealTimeClock_V2.fcfx
(25.3 KiB) Downloaded 593 times
