PH sensing project
Artis
Has thanked: 1 time
PH sensing project
Post by Artis »
Hi i have started to build PH sensing project. I ordered hardware for ph probe from Sparky's Widgets. They have arduino code for it but i want to added some extra options and for that i need transfer code to flowchart.
Does someone have experience  in translating arduino code to flowchart?
Hardware from Sparky's Widgets is getting analog signal and transform it to digital with 12bit  ADC. It has assigned address. 0x4D . Basically i need connect digital sensor with this address.
I will add arduino code below. Sincerely Artis.
P.S. Here can find more info on this hardware http://www.sparkyswidgets.com/portfolio ... interface/
MinipH.rar
(2.75 KiB) Downloaded 324 times
Re: PH sensing project
It looks like you should be able to read the sensor using the I2C component.
Here is a blog on I2C how to use it which should help.
http://www.flowcode.co.uk/blog/simplifie ... c-and-spi/
Artis
Has thanked: 1 time
Post by Artis »
I wiread ph probe to Arduino nano and wrote flowcart but i think something is missing because on hardware its show PH: 0.
mcp3221.pdf
Here is ADC what i use.
(443.79 KiB) Downloaded 290 times
PH (2).fcfx
(9.93 KiB) Downloaded 296 times
howard123
Has thanked: 30 times
Been thanked: 28 times
Post by howard123 »
hello
I think one problem it that you are reading 12 bits into a byte. The two values from the probe can be bytes but the resultant value of your calculation should be an int. You will have to shift one of the bytes 8 bits to the left. I think the MSB comes out first.
good luck
