Print Formatted Number - I2C LCD - Not working
Jay Dee
Has thanked: 121 times
Been thanked: 154 times
Post by Jay Dee »
Hi guys,
I'm pretty sure this is a bug, not me being a clunk.... maybe!
I am using the i2C LCD component and cant print ULong values, Im using the PrintFormattedNumber function.
Both simulate OK.
I also could not get a good result using a conventional 2x20 LCD, it output a value but is not what I expected.
Example FC attached.
Display_ULong.fcfx
example
(13.24 KiB) Downloaded 309 times
Any thoughts?
thanks, J.
Re: Print Formatted Number - I2C LCD - Not working
The problem is not the print routine, it seems to be the calculation that is causing it.
If you change your calculation from
Ans_ULong = Arg1_U16 * Arg2_U16
To
Ans_ULong = Ans_ULong * Arg2_U16
Then it should work as expected.
The first is cast as a 16-bit value when performing the calculation and then assigned to the 32-bit value.
The second uses a 32-bit value in the calculation and so forces the result to also be 32-bit.
Jay Dee
Post by Jay Dee »
Hi Ben,
Thanks for the quick response. I made the change as advised.
Display_ULong2.fcfx
(12.5 KiB) Downloaded 345 times
This now work for the conventional 2x20 LCD,
but still nothing being displayed on the i2C LCD display.
regards, J.
Thanks for letting us know.
I believe I have now found and fixed the problem but have a go and see how you get on.
lcd_I2C.fcpx
(26.12 KiB) Downloaded 338 times
Jay Dee
Post by Jay Dee »
Thanks Ben,
Excellent, that all works with my Hardware.
Promptly resolved and its much appreciated.
J.
