DAC 7V output
For users of Matrix Multimedia Electronics software to discuss projects, circuits and any other electronics concepts.
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
DAC 7V output
Post by Jan Lichtenbelt »
Does someone has a suggestion to realise an DAC with 7Volt maximum output and 30mA?
With kind regards
Jan Lichtenbelt
Re: DAC 7V output
Hi Jan,
Sounds like a job for an op amp. You should be able to make a basic amplifier and use resistor values to give you say 1.5 x gain so 0-5V becomes 0-7.5V. Of course the op amp will need access to the higher voltage for it's positive rail.
Vout = Vin * (1 + (R2 / R1))
R1 = 2K
R2 = 1K
7.5V = 5V * 1.5
https://en.wikipedia.org/wiki/Operation ... _amplifier
It's a good idea to use an Op Amp With a DAC anyway as often the DAC output has extremely low driving current and so an op amp even in unity gain mode (1:1 Input Voltage to Output Voltage) will provide a level of buffering and current amplification.
Beware not all op amps are made the same, some can handle rail to rail outputs and some cannot.
Jan Lichtenbelt
Re: DAC 7V output
The forum https://www.circuitsonline.net/forum/ learned me the OpAmp OPA547. This OpApm needs a voltage between 8 and 60V with a 500 mA output.
It is very interesting for microcontroller user, because the DAC output can directly control the output current of this OpAmp. Just what I need.
Kind regards
Jan Lichtenbelt
PS. OPA in Dutch means grandfather in English. That is in agreement with my age.
opa547.pdf
(925.39 KiB) Downloaded 761 times
