I need the square root of a real ST_Dev. Flowcode made the C-file:
// Calculate the standard deviation
// Calculation:
// St_Dev = sqrt (St_Dev)
// St_Dev = St_Dev / (Nmax - 1)
// Temp = float2int (St_Dev + 0.5) // rounded
FCV_ST_DEV = float32_sqrt(FCV_ST_DEV);
FCV_ST_DEV = flt_div(FCV_ST_DEV, flt_fromi((FCV_NMAX - 1)));
FCV_TEMP = flt_toi(flt_add(FCV_ST_DEV, 0.5));
But I get the error message:
UVmeter_V9.c: main()
1656: FCV_ST_DEV = float32_sqrt(FCV_ST_DEV);
^ (361) function declared implicit int (warning)
UVmeter_V9.c: 1656: (1464) number of arguments passed to function "_float32_sqrt" does not match function's prototype (warning)
UVmeter_V9.c: 1679: (1464) number of arguments passed to function "_float32_sqrt" does not match function's prototype (warning)
0: (499) undefined symbol:
_float32_sqrt(UVmeter_V9.obj)
(908) exit status = 1
What to do?
With kind regards
Jan Lichtenbelt
sqrt error
- Jan Lichtenbelt
- Has thanked: 128 times
- Been thanked: 264 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: sqrt error
Hi Jan,
Thanks for the bug spot.
I'm assuming this is with PIC
Updated CAL file attached, to go into Flowcode7 "CAL\PIC" directory
Leigh
Leigh
- PIC_CAL_Float.c
- (5.19 KiB) Downloaded 251 times
