Problems with custom interrupt
Niro
Has thanked: 29 times
Been thanked: 10 times
Post by Niro »
Hi guys,
new problem... ;-)
I am trying to create an interrupt on PCINT0 (ATmega 328) which calls a macro on every phase change (the FC interrupt only reacts on rising OR falling edge)
Do you have any idea what I'm doing wrong?
Thanks,
Niro
Has thanked: 481 times
Been thanked: 699 times
Re: Problems with custom interrupt
The ATmega datasheet says that a pin change interrupt will trigger if any enabled pin toggles.
So the interrupt will occur on a rising or falling edge.
Are you saying that is not happening?
Niro
Post by Niro »
yes this ist true, that is what I need. But the code I've posted doesn't work.
I only said, that the interrupt macros provided with FC doesn't support this behaviour.
Niro
Post by Niro »
...found the mistake.
The code I've posted is working fine!
Niro
