Cannot compile if channel 1 comms is selected
Zane
Flowcode v5 User
Has thanked: 93 times
Been thanked: 76 times
Post by Zane »
I have PIC32mx270f256b and are unable to compile a program if a UART is connected to channel 1, channel 2 appears to work ok.
The following message is received.
Re: Cannot compile if channel 1 comms is selected
Hello Zane,
Thanks for letting us know. I have replicated the problem and found the fix.
Simply copy this updated CAL file into your "Flowcode 7/CAL/PIC32BIT" folder and then compilation should work correctly on UART channel 1.
PIC32BIT_CAL_UART.c
(22.18 KiB) Downloaded 283 times
Zane
Flowcode v5 User
Post by Zane »
Hi Ben, thanks for sorting a fix for this :D
