Missing Print
Missing Print
In both the File menu and the Tool Bar the print icon is missing. I am running Flowcode 7.1.1 with Windows 10. Thanks
Re: Missing Print
Under the File menu is an item called Create Project report. This creates a breakdown of your program which can be viewed in a HTML web browser and also printed from there.
If you want more control then you can use the Print Screen button on your keyboard and paste the image into Microsoft Paint which will allow you to edit and print the parts of the image you want.
Re: Missing Print
Wow it's interesting that that is allowed yet there is no print button or menu item, I'll investigate this.
Re: Missing Print
Hello guys - I thought.. you'd removed it... (cause it just prints such useless info.. so small - really useless...) so I thought you'd removed it.. !!
no problem.. but a better solution - would win many accolades .. !! indeed.!!
DCW..
DCW..
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Missing Print
We had decided to remove the print functionality because the "create project report" or "save image" options effectively did the same thing. It appears that although we removed the print feature from the menu, we have not totally removed the functionality and Ctrl-P still works.
I think we'll leave the Ctrl-P in there for now, but our "official" line is we suggest using those other menu options ("create project report" or "save image") and printing from there.
