does anyone know how to enable and disable the sleep function in this chip.
I basically want to turn off the sleep function permanently.
thank you in advance
Roy Johnston
18F46K22
Re: 18F46K22
Hi Roy,
The device shouldn't go to sleep on it's own unless told to do so. You may need to check the device configuration settings to make sure the watchdog timer is not enabled if your having problems with the operation of the device.
Roy Johnston
- Flowcode V4 User
- Has thanked: 2 times
- Been thanked: 34 times
