Unable to download software
I have tried twice to download the software but it is failing within the last few mins of download - it gets over 1.0 gb but will not finish the download for some reason?
Thx
Thx
Re: Unable to download software
I'm having the same problem. I'm trying now to save the file rather than open it directly to see if that makes a difference.
Could just be due to high demand, I think some people are downloading ok.
Edit: Nope failed again. Hmm.
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Downloaded on Friday evening, but just saved to the hard drive. Downloaded all ok. Not installed it yet though.
saschech@gmx.de
- Has thanked: 1 time
- Been thanked: 26 times
I hope it is ok:
https://dl.dropboxusercontent.com/u/593 ... .2.0.5.msi
regards wolfgang
dropbox have kill the publik folder......
https://www.magentacloud.de/lnk/ZUPgj6U4
I hope it is ok:
regards wolfgang
Last edited by saschech@gmx.de on Sat Mar 18, 2017 12:27 pm, edited 2 times in total.
I have just downloaded update, and not had an issue.
If I remember correctly, different browsers can cause this issue.
Clearing cache may or may not fix issue.
I use opera because of the built-in VPN so you could try with that browser?
- Has thanked: 1135 times
- Been thanked: 299 times
Downloaded the new version. Uninstall ver. 7.1 and install ver. 7.2 on two PC untill, now, no problem. it seem to work.
Best regard
Jorgen
Best regard
Jorgen
Steve001
- Has thanked: 460 times
- Been thanked: 523 times
downloaded ok but very slow on IE 11 i clicked save as
Took just short of 2 hours this morning
Thx for the replies.
Downloading with MS Edge now instead of Firefox.
Let's see?
Let's see?
Hmm odd...
Downloaded twice with Chrome, twice with Opera. All four downloads are subtly different sizes but over 1Gb. None will run as an install. J. Will wait an see if someone finds something..
EDIT: Downloaded to another laptop. win10, using chrome. all good.
Dont know if it help or you already do it on same way.
I started FC7 go to the helpmenu, check for update, Then I get the message, there is a never version, do you want to download. I save it on my HD. Uninstall version 7.1 and then I run the new install file.
Another way, maybe, you could dowload the trial version from MM home page.. just a thougth.
R jorgen
R jorgen
I have upgraded that as Jorgen described and ..... working.
Thanks the idea.
At first glance, it looks very promising this version.
Congratulation for the MATRIX TEAM.
Lagoda
Thanks the idea.
Lagoda
MS Edge did not work so I installed Opera and I was able to download. However, when I try to install I get an error message that says t is "not a valid windows installer package". This really is a lot of trouble to install a programme, and tends to put one off trying it out!
Thx.
edit..thx for the tip on Opera browser with VPN..fast browser and the VPN is very handy as I sometimes use TOR browser, but it can be very slow
Thx.
- (7 KiB) Downloaded 6369 times
- petesmart
- Has thanked: 187 times
- Been thanked: 140 times
Hello Matrix team,
I attempted a download of 7.2.0.5 this evening using Microsoft edge browser. Download failed at 410, 776 kB – indicated partial download and stopped. The time at which it stopped was 22:26 Sydney Eastern daylight Time
Not sure if that helps – I will try using a another browser – probably Google, I will let you know how I get on.
All the best,
Pete
All the best,
Pete
sorry about that Chief!
- petesmart
Update....
Loaded down with Google chrome...package size 1.055Gb.. File looked like it completed..
Opened Msi file and had the package error come up as below...
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Hey guys,
sorry we are just discussing with our host the possible reasons for this. Ill let you know when its all fixed.
