BUG PWM
Re: BUG PWM
Hi Osta,
I have not got 8MHz crystal so using internal oscillator.
PWM frequency looks correct to me.
One thing I had to do first was disable PLL as you have got clock speed set to 8MHz, yet PLL enabled will make chip run at 8x4 = 32MHz.
So there is a mismatch.
What PWM frequency are you measuring and expecting?
What clock speed are you expecting hardware to run at (8 or 32MHz)?
Re: BUG PWM
Hi, Martin!
All right!
It's not about PLL ...
I need PLL.
If the PWM initialization macro is put after the PWM settings, then everything will change and the PWM frequency will be incorrect!
The same project but with the initialization
All right!
I need PLL.
- Reciever.fcfx
- (5.56 KiB) Downloaded 263 times
Re: BUG PWM
If you're using the PLL then you need to change your clock speed setting to 32000000 in the project options. The properties for the PWM component should then show you what frequencies to expect.
Re: BUG PWM
Hi Osta,
Change Clock speed from to
You are also best having Enable as first component to be accessed.
You also don't require change period if you just have a single fixed PWM frequency.
Just set correct frequency within PWM properties as at least you will know what the frequency should be.
Much better than change period.
Edit: posts crossed so information could be repeated.
In that case you must first go to Build, Project Options then General options tab.Osta wrote:I need PLL.
8000000Code: Select all
32000000You also don't require change period if you just have a single fixed PWM frequency.
Re: BUG PWM
It works the same way ...
From the permutation of the macro, the PWM frequency changes
- Reciever.fcfx
- (5.57 KiB) Downloaded 270 times
Re: BUG PWM
I have just tried using internal osc:
loaded 16F1824 with compiled hex.
PWM from pin C5: As hardware agrees with PWM settings within Flowcode, I can't tell what the issue is?
If you can measure frequency, can you set to enabled, within configuration settings.
Then measure frequency on pin A3.
You should measure 32/4 8MHz even though clock is running at 32 MHz.
Clock out enableThen measure frequency on pin A3.
Re: BUG PWM
Hi, Martin !
I'm not talking about setting up.
And about the compilation ....
Here is my example.
Here is my example.
- Initialization at the bottom
- (932.67 KiB) Downloaded 38 times
- Initialization at the top
- (937.37 KiB) Downloaded 38 times
Re: BUG PWM
The PWM Enable component macro calls the Change Period for you using the values in the component properties.
If you want to use values other than those specified in the properties then you need to call the Change Period macro again after enabling the PWM.
Re: BUG PWM
Hello Benj!
I thought that the linker has priorities,
Thank you for the clarification.
Thank you Osta.
Thank you Osta.
