EB063-433
robertenrosa
EB063-433
Post by robertenrosa »
I am new with the flowcode and E-block.
I recently purchaged a EB031( arm ) and a EB063( RF-433 ) and testing with flowcode 7( 30 days trial )
Have downloaded examples, have tried the port B and C with pins in the examples, but i can't get it to work.
The initialise always returns a 0.
Is there someone who can help me with this, all other devices like LCD, RFID ect are working fine, but this is a mind teaser.
Thanks in advance,
Rob
RF_Test1.fcfx
(14.7 KiB) Downloaded 392 times
robertenrosa
Re: EB063-433
Is there nobody who can help me here, i would like to make this work.
Thanks,
Rob V
Has thanked: 481 times
Been thanked: 699 times
Re: EB063-433
You need to check that the RF-ISM component connection properties match your e-block jumper setting, details are in the EB063 datasheet.
For example, if you attach to port B and set the EB063 patch jumper to position A, your properties should be as below ...
Hope that helps,
Leigh
robertenrosa
Re: EB063-433
Hello Leigh,
Thanks for your reply, you are correct, but when i look to the ARM processor pins, the MOSI and MISO are on bit 4 and 5 at port B, this means the jumper on B.
I have tried your suggestion also, but with no luck.
I really do know know why this is not working, it should be so simple.
Hope you have more ideas.
Rob
