Aid, threshold voltage
samtin
Has thanked: 1 time
Post by samtin »
Hello everybody,
A cheaper solution, do not use too much memory
and it works very well, may set any threshold voltage.
Thanks Matrix
(29.12 KiB) Downloaded 5039 times
Re: Aid, threshold voltage
There are some functions in the calculation icon that can help with doing float comparisons.
Here I check to see if the value in the float variable is greater than 10.0.
If it is then comp will have the value 1 if the variable is greater than 10.0, otherwise comp will equal 0.
samtin
Has thanked: 1 time
Post by samtin »
Hi Benj,
Thanks very much for your help Benj, I will try the version proposed.
Thanks again
samtin
Has thanked: 1 time
Post by samtin »
Hi Benj,
I tried and it works great.
Respect for you.
Thank you very much! :D
