Just noticed that flowcode 7.2.1 is out , what is new in 7.2.1 ?
Flowcode 7.2.1
Re: Flowcode 7.2.1
Hi Alan,
From the logs folder:
- * Components *
- Feature additions -
Formula AllCode added read all sensors macros to API component
Added better help to CAL UART change baud macro
- Bug fixes -
Fixed ModBus Slave could only receive and process a maximum of 40 bytes
Fixed ModBus Slave simulation had fallen behind embedded functionality
* Tools and plugins *
* CAL changes *
- Bug fixes -
PIC32 Delays
PIC32 devices not resetting correctly under ICD - fixed ICD reset function
ICD variable read/write confirmed working from Virtual address 0xA0000000 onwards
PIC32 ICD timeout increased from 1000 to 65535 to ensure comms are more reliable
Fixed a problem with fround functions where the definition added 0.5 but then called a function which added another 0.5
* FCD changes *
- Bug fixes -
Misc ARM targets were missing the compiler options overrides
PIC16F68x devices missing INTOSC helper XML section
Rolled out timer fix to more PIC16BIT devices
Improved timer handling on some 16-bit PIC Misc devices
changed PIC32 compiler overrides from .cof file to .elf file for ICD compatibility
* Compiler changes *
* Flowcode executable *
Cursor Keys on Properties Window
- Bug fixes -
Component configuration redraw issues
Fixed a crash that occured while exiting Flowcode while the simulation was running
Fixed an issue where setting a breakpoint while in ICD mode was not working while ICD was running at full speed
StartPage casted as Flowchart and executing as Flowchart
Ghost settings now save with the project
Restore defaults button in Ghost settings now works correctly
Fixed an issue where the override comms delay settings was not being saved when OK was clocked
Time Interrupt is more accurate in simulation
Fixed an issue where if the target device of a project ever got changed then you could sometimes end up with both a .cof file and a .elf file existing at the same time which would cause issues with ICD variable values not displaying correctly if the wrong file was read.
Fixed an issue where .elf files were being generated with the wrong file extension for PIC32 devices
Fixed an issue with the Flowkit 2 clock and data pin selection in Ghost settings
Fixed a crash when using Flowkit 2 with PIC32 devices
Fixed an issed with Ghost on Flowkit 2 not correctly reading and writing to memory on PIC32 devices
- Cosmetic changes -
Fixed the toolbar so the icons are cleared when in ICD mode
