[SOLVED] 16F18877 hardware UART bug
EtsDriver
Has thanked: 345 times
Been thanked: 227 times
Post by EtsDriver »
Hi!
Hardware uart channel 1 seems to be messed up, when trying to compile for hardware uart, demands remapping of pins (they are hw channel in C6, C7) and the log returns errors.
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe  --chip=16F18877 "SW_LEDTEST.c" --MSGDISABLE=359,1273,1388
Microchip MPLAB XC8 C Compiler (Free Mode) V1.41
Build date: Jan 24 2017
Part Support Version: 1.41
Copyright (C) 2017 Microchip Technology Inc.
C:\Program Files (x86)\Flowcode 7\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Init_1()
   325:	PIE1bits.RCIE = 0;
	              ^ (255) not a member of the struct/union ""
	                 ^ (182) illegal conversion between types
int -> volatile union S986
C:\Program Files (x86)\Flowcode 7\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Send_1()
   431:	while ((PIR1bits.TXIF) == 0);
	                           ^ (207) simple type required for "=="
C:\Program Files (x86)\Flowcode 7\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Receive_1()
   511:	regcheck = (PIR1bits.RCIF);
volatile union S967 -> unsigned char
	                          ^ (181) non-scalar types can't be converted to other types
C:\Program Files (x86)\Flowcode 7\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_UpdateBaud_1()
   728:	PIE1bits.RCIE = 0;
(908) exit status = 1
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe reported error code 1
FINISHED
Software channel compiles ok:
Memory Summary:
    Program space        used   143h (   323) of  8000h words   (  1.0%)
    Data space           used    32h (    50) of  1000h bytes   (  1.2%)
    EEPROM space         used     0h (     0) of   100h bytes   (  0.0%)
    Data stack space     used     0h (     0) of   FCDh bytes   (  0.0%)
    Configuration bits   used     5h (     5) of     5h words   (100.0%)
    ID Location space    used     0h (     0) of     4h bytes   (  0.0%)
You have compiled in FREE mode.
Using Omniscient Code Generation that is available in PRO mode,
you could have produced up to 60% smaller and 400% faster code.
See http://www.microchip.com/MPLABXCcompilers for more information.
C:\Program Files (x86)\Flowcode 7\tools\DoNothing\DoNothing.exe
FINISHED
Re: 16F18877 hardware UART bug
Thanks for letting us know.
I believe I have now solved the problem.
Simply copy the attached into your "Flowcode 7/CAL/PIC" folder and the problem should be resolved.
PIC_CAL_UART.c
(20.92 KiB) Downloaded 340 times
Let me know how you get on.
EtsDriver
Re: [SOLVED] 16F18877 hardware UART bug
Post by EtsDriver »
Marked as solved, works on hw now!
