I am a newbie in the compiler and I met some troubles now. Can you solve it ?
Maybe my question is simple to you.Please look at the following program:
Rebuild target 'Target 1'
compiling Serial-test.c...
linking...
LX51 LINKER/LOCATER V4.66.41.0 - SN: T1PMC-JQ522C
COPYRIGHT ARM Germany GmbH 1995 - 2015
@SERIAL~1.LNP "Serial-test.obj"
TO "Serial-test"
PRINT(".\Listings\Serial-test.map")
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 00BBH BYTE ( 9%) *
Program Size: data=15.0 xdata=0 const=10 code=321
*** ERROR L257: UNKNOWN
Target not created.
Build Time Elapsed: 00:00:00Thanks a lot.
