Microchip powered by Li batteries
For users of Matrix Multimedia Electronics software to discuss projects, circuits and any other electronics concepts.
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Post by Jan Lichtenbelt »
Using AA batteries has been described earlier: http://www.flowcode.co.uk/mmforums/viewt ... =3&t=16841
The voltages of Li batteries are between 3.6 and 4.2 Volt. When the 3.3Volt microchips are used, a simple low drop voltage regulator LP2950-3.3 can be used, if the Li battery voltage is at least 3.8 Volt.
There is a very interesting alternative. The DC-DC convertor PTN0405C from Texas Instruments changes an input voltage from 2.95 to 5.5 Volt into an output voltage of 5-15Volt, just by changing one resistor. No coil is needed, only 2 capacitors. Using a Li-battery in connection with this converter, it is possible to use the regular 5 Volt microchips. In this case, even the resistor is not needed.
6W and 12W converter are available
Easy to handle PCB
Easy to handle PCB
With kind regards
Jan Lichtenbelt
Datasheet: See Farnell http://www.farnell.com/ and search for PTN0405
