Compile ERROR with PIC 12F683 chip
MTTweaker
Has thanked: 3 times
Post by MTTweaker »
I get an error when I compile, seems to be an issue with the IOC pin config.
BUT it compiles fine with flowcode 6
RC switch_12F683_20MHz.fcfx
(15.52 KiB) Downloaded 294 times
Re: Compile ERROR with PIC 12F683 chip
Hi MTTweaker,
If you have 64 bit windows then replace attached file in:
C:\Program Files (x86)\Flowcode 7\FCD\PIC\
If you have 32 bit windows then replace attached file in:
C:\Program File\Flowcode 7\FCD\PIC\
12F683.fcdx
(13.02 KiB) Downloaded 256 times
Thanks Martin,
Found a few more devices with this same problem. ioc= instead of IOC=.
PIC.zip
(13.44 KiB) Downloaded 298 times
