LED Array pin labels not showing:
I have changed label position to left and sill not showing.
LED 5mm that's also add:
Pin label also does not show when left on the default top.
When changed to any others (left, right Etc) then pin label does appear.
LED Array Pin Labels
Re: LED Array Pin Labels
Hi Martin,
I've looked at these before, these components are rather complicated, much more so then they should be. Something like 5 nested components all with inter related properties and dependencies. They were done in the early days of v6 and basically need ripping up and starting again.
I've made a note to have a proper investigation and try and get these sorted properly.
Right I've had a pass through and think I have fixed the label problems.
Simply extract the attached archive to your "Flowcode 7/components" folder, restart Flowcode and the problems should be fixed.
Let me know how you get on.
Hi Ben, the 5mm LED is perfect!
However the LED array label only now shows at the top.
It does not matter what position the label is showing: Unless deliberate?
Thanks Martin,
Nope not deliberate, investigating now.
Thanks Martin, Good find!
You're right it did have another separate issue, hopefully fixed now.
That's it.
Left and right have been left off.
So if that's intended then working perfectly.
Thanks Ben
Thanks Ben
