Vref-
Re: Vref-
In a C icon you can use this code.
Note that the ADC CAL will probably overwrite your adcon1 setting, looking at the code yes it does.
The 18F4550 uses ADC type 13 so if you look at the file "Flowcode 6/CAL/PIC/PIC_CAL_ADC.c" in a text editor you will see that ADC type 13 starts around line 1683.
Inside the ADC Type 13 look for the line
Before this line add your altered code.
Then the VREF- will get switched on for you by the ADC component.
Please note that a text editor will be unable to save the file if Flowcode is located inside the Program files directory. Instead you will have to save the file to your desktop and then manually copy it back into position using Windows explorer.
We recommend you make a backup of the original file so you can revert back if you need to.
set_bit(adcon1, 5);The 18F4550 uses ADC type 13 so if you look at the file "Flowcode 6/CAL/PIC/PIC_CAL_ADC.c" in a text editor you will see that ADC type 13 starts around line 1683.
#ifdef MX_ADC_TYPE_13Code: Select all
old_tris = *tris_reg; //store old tris value, and set the i/o pin as an inputCode: Select all
set_bit(adcon1, 5);Please note that a text editor will be unable to save the file if Flowcode is located inside the Program files directory. Instead you will have to save the file to your desktop and then manually copy it back into position using Windows explorer.
