I receive the following error in the FC7 version but not the FC6 version; "Options have been disabled due to restricted license".
This is given after the compiler is launched, and regardless of which compiler I select. Any idea why?
I am attaching the code for the test program.
Thank you.
- TIMER_PIC24FJ64GB002__PLL_clock_8_MHz.fcfx
- (22.6 KiB) Downloaded 266 times
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: Options have been disabled due to restricted license
Hi"Options have been disabled due to restricted license".
Your Flowchart compile fine with me in FC6 and FC 7
what you are seeing in FC7 is normal and it not an error , the compiler is telling you that you are using it in Free mode and the high level optimizations are disabled ,this is normal and no problem you code will run on Hardware.
- 1.JPG (48.94 KiB) Viewed 2578 times
Regards QMESAR
Regards QMESAR
