wrong hex file generation
jsmith321
Post by jsmith321 »
Wrong hex file generated for device PIC12F675.
The 9.2.5.1 Calibrating the Internal Oscillator says in the pdf that 'call 3FFh' have to call to program OSCCAL and in this case RETLW xxx should be at 0x3FFF at flash. In the hex file 'call 3FFh' called however at 0x3FFF is a NOP and the program hangs up.
Re: wrong hex file generation
Hello and welcome to the forums,
Please can you post your project file and give us some more information on the problem you are experiencing.
jsmith321
Post by jsmith321 »
The hex file is wrong. Can't simulate the hex file with an other program.
Flash-Test.fcfx
(9.04 KiB) Downloaded 185 times
