Wake Up from CAN_BUS
Barmaley_GMN
Has thanked: 8 times
Been thanked: 4 times
Post by Barmaley_GMN »
Hi!
I need help)
I have Pic 18f2580 and MCP2551 connected to internal CAN-BUS.
I tried wake PIC up by RXINT, but it doesn't work.
How can I wake PIC up by activity in CAN-BUS?
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Wake Up from CAN_BUS
Post by QMESAR »
Barmaley_GMN wrote: I tried wake PIC up by RXINT, but it doesn't work.
Have you configured the CAN module to wake up on RX messages?
you need to post your minimal Flowchart that shows your configuration of the CAN module.
Barmaley_GMN
No. I just set the timer to RXINT and set Sleep()
I don't know if the macro TMR RXINT set configuration bit for wake up by activity on RX can-bus or it makes it for UART RX.
As I see, I need to set REQOP2:REQOP0 = 001 and WAKIF = 1. That's it?
QMESAR
Post by QMESAR »
Barmaley_GMN wrote:No. I just set the timer to RXINT and set Sleep()
with out seeing your Flowchart and configuration settings it is hard to help ,
According to the device datasheet in my understanding is that you have to configure a CAN wakup interrupt which will be triggered when there is a message(activity) on the bus and the device is in sleep mode,
I do not think "That's it" as mentioned :D
Barmaley_GMN
cr_bit(cancon, REQOP2);
cr_bit(cancon, REQOP1);
st_bit(cancon, REQOP0);
st_bit(pie3, WAKIE);
This way?
I may be wrong on this but it looks like you just need to use this C code to enable the wake from sleep and reset the interrupt flag.
cr_bit(pir3, WAKIF)  //Clear interrupt flag if set - re-arm interrupt
st_bit(pie3, WAKIE);  //Enable interrupt
st_bit(intcon, PEIE);  //Enable Peripheral Interrupts
st_bit(intcon, GIE);  //Enable Global Interrupts
Barmaley_GMN
There is mistake
it is read only bit.
And I haven't managed to make interrupt on CAN-BUS.
It stops transmit, but doesn't wake up the chip.
Now I think the problem is in the another interrupt (I'm using 2 interrupts in one program) When the first (by timer) is run - the second(by wake up) is off. Then the first stop the second run. And the second doesn't work.
Barmaley_GMN
TimerSleep.fcf
(17.5 KiB) Downloaded 448 times
I have managed with wake up. But I used only one interrupt (by CAN activity). Now I have additional problems: after waking up it doesn't go sleep in next cycles.
Barmaley_GMN
clear_bit(pir3, WAKIF); // clear interrupt
This is right way.
Interrupt
Enable code
intcon.GIE = 1; // Enable global interrupts
intcon.PEIE = 1; // Enable peripheral interrupts
st_bit(pie3, WAKIE);  //Enable interrupt CAN
Handler code:
if (pir3 & (1 << WAKIF))
FCM_%n(); // call selected macro
Barmaley_GMN
I need help!
Code for Pic18f2580 doesn't work with 18f25K80
I see error in text box
DRL+V7-2.c(6768:23): error: unknown identifier 'REQOP0'
DRL+V7-2.c(6768:23): error: invalid operand 'REQOP0'
DRL+V7-2.c(6768:18): error: failed to generate expression
DRL+V7-2.c(6768:18): error: invalid operand '<<'
DRL+V7-2.c(6768:12): error: failed to generate expression
DRL+V7-2.c(6769:24): error: unknown identifier 'REQOP1'
DRL+V7-2.c(6769:24): error: invalid operand 'REQOP1'
DRL+V7-2.c(6769:19): error: failed to generate expression
DRL+V7-2.c(6769:15): error: invalid operand '~(1 << ( REQOP1))'
DRL+V7-2.c(6769:12): error: failed to generate expression
DRL+V7-2.c(6770:24): error: unknown identifier 'REQOP2'
DRL+V7-2.c(6770:24): error: invalid operand 'REQOP2'
DRL+V7-2.c(6770:19): error: failed to generate expression
DRL+V7-2.c(6770:15): error: invalid operand '~(1 << ( REQOP2))'
DRL+V7-2.c(6770:12): error: failed to generate expression
What can I do?
Barmaley_GMN
I have solved the problem.
18f25K80.h doesn't have these bits in cancon register unlike 18f2580.h
So I can write cancon = 0x20
or add to 18f25k80 bits intto cancon_ro7
